need switched ingnition power source
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kumma, Mar 4, 2002.
  1. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    ok i know very little about elcetrical connections, i need to splice into a switched ignition power line in the engine compartment. my truck is an 87 350 tbi. any suggestions.
    craig
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I would check for an available "IGN" terminal on the fuse box. If there isn't one, the wire colors should be:
    Big Brown - ACC
    Big Pink - Ignition
  3. dyeager535
    26,982
    191
    BTW, its very easy to go to a wrecking yard and cut the correct fuse panel accessory plug off of a car or truck that has an IGN acessory plug, then splice your wire and the connector. Nice, clean, secure connection.
  4. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    you can also use the male connector off of a crimpy dealie ... fits in there just right and doesn't go anywhere
