Need T-case crossmember for 91 K5
Discussion in 'Parts & Trucks Wanted' started by Boscolingus, Nov 26, 2001.
  1. Boscolingus
    Boscolingus 1/2 ton status
    Nov 26, 2001
    210
    Santa Clarita, CA
    wondering if anybody may have a leaad as to where I can find this and many other parts
    Got my 91 K5 back after 2 years - and man I need parts - BAD!!!!
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    How would this differ from any other t-case crossmember? I have one out of a 77 blazer that had a th350 and 203.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. Boscolingus
    Nov 26, 2001
    210
    Santa Clarita, CA
    hey - if it works, then it works - are you willing to part with it?
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    yeah it's just sitting here, it was left over from when I swapped the running gear over to my Jimmy. make me an offer, that I can't refuse.
    55 Willy's
  5. Boscolingus
    Nov 26, 2001
    210
    Santa Clarita, CA
    so would this work for a 91 K5? ( 700 R4 w/ NP 241C ) - if so then sure, Im sorry for lacking knowledge here, but I stumbled on this forum tonight and I am absolutely grateful that Iv'e found it - I just might get my baby back on the road after all
    as far as an offer, well - if I say to little then I might piss you off, too much then its a blow to me, how much do these things go for, I'm trying everything in the world here so as I dont have to wind up fabricating all these parts, theres no sense in re-inventing the wheel
  6. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Those cross members are completely different. You need a cross member from a 208 or a 241 transfer case. I have one here from a 1985 208, with the skid plate and also one from an 88 208, I believe they are both the same. I drive a 91 suburban with the same driveline as yours so I will confirm that they are the same. They are in good shape. How does $65 to your door, blasted and painted sound?
    Let me know,
    Mike
    The jeep eater ......jeep it's what's for dinner[​IMG]
  7. Boscolingus
    Nov 26, 2001
    210
    Santa Clarita, CA
    dude - you are a saviour beyond description, where do I send the check/ money order/ or what have you...
    the next step id finding a transfer case ( NP241 )
  8. mpascino
    Jan 1, 2001
    557
    Connecticut
    ever heard of pay pal online, it is used a lot on ebay. If not you can send a money order to me.
  9. Boscolingus
    Nov 26, 2001
    210
    Santa Clarita, CA
    not too familiar with pay-pal, however I can get a money order for you, what address should I send it to?
  10. mpascino
    Jan 1, 2001
    557
    Connecticut
    check your private messages.
    Mike
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Just so you and everybody else will know for future reference, there are different types of crossmembers.
    '73-'84 are all the "flat" members which use the "tall" adaptors for the tranny and t-case.
    '85 and '86 are the "double hump" members.
    '87 up to '91 are also "double hump" members, but they are a little different than the '85 and '86. The only difference between these two are the areas on the crossmembers where the skid plates bolt to. An '85 skid plate will not bolt onto an '91 crossmember, and vice versa.
    Since you have a '91, you CAN use the '85 and '86 members, but you will need a skid plate from those years, too.
    Just don't go with any crossmember older than '85 and you will be just fine.
    Only use the pre-'85 crossmember if you plan to do a tranny/t-case swap and it has the "tall" adaptor. [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
