need tail light wiring diagram
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kumma, Dec 10, 2001.
  1. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    the previous owner spliced in a trailer harness, which was hastily cut off when i replaced the rear floor. it was rewired but its not correct. the reverse lights come on when the right turn signal is activated. and the right rear running light goes out when the brakes are pressed. any one have a link to a diagram.
    "Why is there a <font color=red>watermelon</font color=red> here?"
  2. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    what year? I have manual for up to 84... I can scan the page and send it to you.
    Brian
    <a target="_blank" href=http://www.saddletramps.com/BlazerK5.htm>www.saddletramps.com/BlazerK5.htm</a>
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    The reverse lights coming on when the right turn signal sounds like something is definatly crossed...
    As for the right rear running light going out when the brakes are pressed, check for a bad ground right there, the socket for the light bulb is usually case grounded.
    You're describing a problem with the lights that I had once.. turned out to be that bad ground.
    my 2 cents
  4. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    i've got a manual for my '89, i bet your '87 is the same. i can fax it to you, i'm not sure of my scanning capabilities here at work...
    <font color=purple>delta9blazer</font color=purple>
  5. kumma
    Oct 29, 2000
    380
    Novi, Michigan
    its a 87 jimmy i think it would be the same. you can fax me at 248-380-1690. thanks.
