Need tailgate hinges and all hardware
Discussion in 'Parts & Trucks Wanted' started by dpmalibu, Sep 25, 2006.
  1. dpmalibu
    dpmalibu 1/2 ton status
    Sep 24, 2005
    388
    Trenton,NJ
    Need tailgate hinges and hardware(evrything needed to install a tailgate) for 1974 Short bed P/U.
  2. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    I have these for an 86. Would it be the same?
  3. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    have a 74 lwb chevy i'm parting out let me know if you need anything else
  4. dpmalibu
    Sep 24, 2005
    388
    Trenton,NJ
    The hinges from an 86 are different. The only parts I need are the tailgate hinges at this point.I'll let you know if I need anything else.
  5. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I have a pair of hinges off of a 74 or 79 dont recall the year. I think I used the pivots, I would have to check.
  6. dpmalibu
    Sep 24, 2005
    388
    Trenton,NJ
    Those are the parts.How much do you want for everything?
  7. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    $20 shipped and Ill check on the pivots tonight.
  8. dpmalibu
    Sep 24, 2005
    388
    Trenton,NJ
    Sounds good.Let me know.
  9. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Yeap just as I thought, hinges only, the pivots I used to hold my bedsides on. :D
  10. dpmalibu
    Sep 24, 2005
    388
    Trenton,NJ
    So all you have is the hinges?
  11. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    correct, the hinges in the picture. The other pieces got used.
  12. dpmalibu
    Sep 24, 2005
    388
    Trenton,NJ
    Okay.Thanks anyway. Anybody else have all the pieces that are pictured above?
  13. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I think you should double check, I'm pretty sure the later ones will fit both an older gate and the truck. Good luck.
  14. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    OH I came across another setup yesterday while cleaning. Ill get a pic later today.
  15. dpmalibu
    Sep 24, 2005
    388
    Trenton,NJ
    The newer set uo does not work. I aready had them. The 73-80 tailgates are different from the 81-87's.
  16. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    In another couple of posts while trying to figure this out for myself, the consensus was that the hardware must match tailgate, but either setup pre or post 80 will work. :dunno:
  17. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Heres the pair that I found over the weekend. From a 79 blazer.[​IMG]
