Need temp frt locker! Weld the 60?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jul 18, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I've got a few trips to make this year that I will need a front locker... and I've only got a month to prepare. I still need to relocate my rear shocks, buy 2 36" TSLs (2 of mine are nearly shot), and buy trail parts IE spare 1350's etc.
    SO - my question is... does anyone see a problem with welding the front? I know its been done, and most of the time people warn of how undriveable it will be in the rain/snow in 4WD... but my truck rarely sees 4WD on the street. And on the trails, I can have a spotter unlock one side if I need to make a sharp turn.
    Should I do that to my D60? I plan to eventually get some kind of REAL locking device... but I can't produce that $$$ and purchase everything for my runs within one month. Suggestions?
    /forums/images/icons/smile.gif
    -Dan
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Are you going to Moab? The traction on that sandstone is pretty incredible. I think a welded front diff would have you wrestling with the steering wheel most of the day. /forums/images/icons/frown.gif
  3. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Moab... well... I don't think so. I am seriously bummed about it... but I don't think I can make it. The money that I saved for the trip was used "other places" and its just not going to happen this year. /forums/images/icons/frown.gif:(:( I was really bummed when I figured that out... /forums/images/icons/frown.gif
    But anywho... I still need a front locker! To weld or not to weld! That is the question! /forums/images/icons/cool.gif
    -Dan
  4. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Without some kind of hydro assist steering, turning with a locked/welded front diff will be difficult if you're not moving much. But, remember how much fun those hills were in Disney with an open front diff? /forums/images/icons/smile.gif
    I say do it, and just muscle the wheel around on those tight turns /forums/images/icons/wink.gif
    BIGJ
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you're gonna play in the woods with me, it'd be a fairly bad idea to lock the front unless you want to hit a tree. I was going to do it but I chickened out now. On some trails wide open is the only way you keep from getting stuck and sometimes turning is involved at the same time.
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The only way that I would want a spool or welded front diff is if I had the t-case twinsticked so I could just use front wheel drive to make turns sharper. You could always unlock a hub, but do you use a spotter on every sharp turn? It's going to get old getting out and unlocking a hub every time you need to negotiate through a tight spot. </font color>
