Need Timing/idle set near Renton, WA
Discussion in 'Pacific Region' started by kennyw, May 10, 2005.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I didn't get the time to set the timing and idle on the Jeep I sold my sister before she got here. Anyone close to Renton have a timing light that would do it for a little cash? Or recomend a shop that won't try to rip her off. It is on a 2.5L 1985 Jeep Cherokee.
  2. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    hey kenny call jack and ask him if you stil have his # he lives down close to there and might do it.
  3. dyeager535
    26,979
    Is it same procedure as Chev?
    I think I've still got the timing light I borrowed from my dad...
    I'm available Fridays during the day, typically I'm there Fri-Sun, but I've got to work Sat-Sun this weekend.
  4. kennyw
    Jun 9, 2002
    13,223
    94
    Same basic procedure as GM small blocks, disconnect vacuum advance and plug, set timing to 12* btdc, set idle to 750 RPM (tach in dash should be good enough for that). Double check timing then reconnect the vacuum advance if it's good to go. I just ran out of time before I got to it. It already has a rebuilt carb, rebuilt distributor, new plugs, cap, rotor, wires, ignition module, starter, battery, etc...
  5. kennyw
    Jun 9, 2002
    13,223
    94
    I'll check with Jack as well.
  6. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    I can do it, I'm in renton. Let me know
