Need tips on kingpin change - working it this weekend
Discussion in 'The Garage' started by mouse, Nov 3, 2006.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    In the middle of changing them right now. I have been referencing Billavista's writeup at Pirate, and amazingly, the kingpin came out with little problem. I hadn't wanted to change it, but when I got it apart I found the old one to be pitted and galled.
    A local tool shop had the 7/8" allen key. A 3 foot cheater bar and some heat, and the kingpin was off :D .
    What I am having problems with is installing the new lower race. I tried driving it in with a ballpean and 2x4, but its not going in far. I'm calling it a day, but maybe tomorrow I'll try using my balljoint press to squeeze it in.
    BTW, I have cleaned the bore with a scotch brite pad and used oil to try to make it install easier...not happening.
    I need ideas!
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Stick it in the freezer over night. :wink1: Seriously...Heat will make it expand, cold will make it contract. Well unless you welded on the inside of it then it would make it contract onto itself but then it would be useless.
  3. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Good Idea...I need to beat it out of there...:rolleyes:
    It came right out. I'll freeze them both tonight and use the ball joint press tomorrow and hopefully they'll go back in.
    Oh yeah, this is just the passenger side. I still have the drivers to start.
    When I bought the allen key they had one that was 1 1/4 inch for only $186.95!
    I have also welded on a nipple...err...zerk guard on the bottom plate.
