Need to adjust my blinker 1972, k5
Discussion in 'OffRoad Design' started by TONYP, Aug 28, 2002.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    my blinkers turn off clicker for a right turn is set to click off with the steering wheel at 12:00, so as I put the blinker on it goes off if the wheel is not turned to the right. If it is set on with the wheel turned to the right, it will click off when the wheel goes back to 12:00. ie:coming up to a turn I have to hold it on... any one know how to adjust? Is it in the steering wheel or can I adjust the steering shaft?
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    You should ask this question in the first Generation forum and you will get good responses.
