Need to bench-bleed a CLUTCH master cylinder...?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Apr 23, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I know you have to bench-bleed a brake master cylinder before you install it, but is the same true with a clutch master cylinder...? Thanks for the input...
    Chris
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    would make sense... but honestly i am not sure. i bench bleed anything i can first. makes it easier most of the time.
    grant
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Hydrualic clutches can be a real PITA sometimes.
    At work I back bleed the system.
    I have a pump with a hose that fits over the bleed screw and I fill the system from the slave cylinder first and unbolted from the tranny.
    When the resevoir gets close to the full mark I close the bleeder and bolt up the slave cylinder.
    9 times out of 10 when you test the pedal it is nice and solid and not mushy.
  4. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
    YES YES YES!!!
    I think that it is the same for any hyd. clutch system. I went through 3 clutch master cylinders on my Camaro because the directions didn't say crap about bench bleeding it. After the second one broke (due to opening and closing the bleeder screw, then stripping it out) we filled it up, bolted it up and had a good pedal with about three bleeds.
    Shane-
