Need to cut steel
Discussion in 'The Garage' started by BLZN4FN, Mar 30, 2005.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I need to cut a 3 inch hole in 1/4 plate steel what would you use?
    This is what I have. Drill press,anglegrinder,sabersaw. Do you think I can make any of these work. like maybe drill press with a hole saw?
    Let me know what you think.
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Drill Press with hole saw and cutting oil.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What he said, just take your time.
  4. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    Well I will give the drill press a try.
    Let you know how it worked out :D
  5. velocitiii
    velocitiii Registered Member
    Dec 19, 2003
    54
    don't forget to oil that hole saw as you cut. cutting oil, valvoline, used motor oil, anything will do.
  6. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I've never used oil with a hole saw, does it really help?
  7. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    Tons! They make special cutting lubricants. A bit of humble advice:
    try not to use anything too flamable.
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Glad to see that I'm not the only one to learn this the hard way.
  9. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    dont run your rpm too fast, you will dull the saw, yes on the oil too. about 100 rpm or slower, any faster and you will get some chatter which is hard on the saw teeth, let it cut, dont force it too hard.
  10. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
  11. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If your drill press won't go slow enough to prevent chatter I would suggest the old fashioned way. Scribe a circle of the size of hole you need and drill a series of small holes all the way around the circle. Then you can easily cut out the center and file to shape and size. It is easy work, just time consuming.
  12. afroman006
    Aug 21, 2002
    2,876
    Ok I guess I'll use oil from now on. I've been just drilling dry with no problems yet but havent done a whole lot of holes. My press only goes down to 300 rpm, it works fine but I have to take it really easy or it will bind and the belt on the press will start sliping. And yes I agree clamping the part to the table is esential.
