Need to get wheel joints out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Nov 12, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I'm trying to change out the wheel joints in my front axle. They are the factory original spicer and are shot really really bad. I have the axle shafts out but the dang caps seem to be frozen into the shafts. I've tried soaking them in PB Blaster... heating it using my little small torch and using my press (little 6 ton $60 special [​IMG]). I cannot get these caps out to save my life. Anyone have any ideas? Maybe Drill down the center and keep working with it? Just trying to think of stuff I haven't tried. Any help would be great. I could always take it to a shop with a good press but that is my last resort.
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Did you remove the retainer rings? If you cant see them start scraping all the grime off. If you do have the off lay the yoke of one side across the open hole of your vise and with a 3lb hammer hit the other yoke that is now verticle and it will come loose.
    I thought I was wrong once,
    but I was mistaken
  3. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Yes I did remove the retainer rings... I'll give it a go when I get home.
  4. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I had some trouble removing mine with a 12 ton Hydro press [​IMG]. Good luck with the 6 tonner [​IMG]
    Mine let go with the LOUDEST BANG!! I thought I broke the press!! [​IMG]
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  5. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    The last one I did I ended up cutting the U-joint cross out with an angle grinder and a cut off disc and then using a 'drift' and a BFH on the U-joint cups...even then the U-joint cup broke and the drift went through the center of the cup...[​IMG] Eventually it all did come out but what a PITA!!! I guess that one had been in there for a while.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  6. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Stupid question but what exactly is a "drift"? Never used one and I need to know to find out if my dad has one...haha
  7. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    A 'drift' can be almost anything. You place the drift angaist the part that needs to move and smack it with the BFH...In my case I used an old punch that had broken. I ground the end flat and turned it into a drift...
    I have a selection of drifts in my toolbox at work, some aluminum, brass and plain old mild steel round stock.
    Rene
  8. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    your trying to get the U joints out ?these are factory right ? they have plastic keepers that basicly need to be torched out ,on the side youll see plastic nubs where its injected .heat them up then hit it with a socket and big hammer.
    88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.11
  9. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Rene... Gotcha... ok I basically always used an old socket.
    coopertwpk.. These are factory (as far as I can tell) but I do not remember seeing any plastic pieces. I did torch one end and it wouldn't budge but I'll have to check again.
  10. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I ran into one of thoes plastic injected Ujoints on my S10 and I did melt out one but didn't know there were two. Long story short I took my Oxy/Ac torch and blasted it out!! The cap melts way quicker than the yoke/ear so no damage and the new joint whent in fine.
    Yours is probly fuzzed so torch it out if you have one!!
    Good Luck
    <a target="_blank" href=http://coloradok5.com/gallery/Burt4x4>http://coloradok5.com/gallery/Burt4x4</a>
  11. 91gmcjimmyCH_IL
    91gmcjimmyCH_IL 1/2 ton status
    May 24, 2001
    110
    Grayslake, IL
    I didn't have a torch to get my plastic crap out so i used a 20 dollar propane torch kit. It took a long time so I kept hitting them with a BFH and it wouldn't budge so finally I said FT and just kept torching it and then the fiberglass ring started squirting out of a tiny whole and then a couple bangs with the BFH and it came right out.
  12. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Well I'm a bit ticked... Ok... I tried everything with these and nothing would make them budge. I looked all around them and didn't see any plastic pieces. Now the reason I'm ticked is while I was trying to take the caps out with my press... The shaft on my press BENT!! So now I'm out a press and the caps didn't even budge. I was like... COME ON!!! YOU GOTTA BE KIDDING!! Oh well... looks like I gotta take the shafts to a shop to have the joints changed out. Just needed to Yell for a sec... Makes ya feel better ya know [​IMG].
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I used a 10 ton press to get mine out. They were 18 years old and they literally exploded.
    Many people say that 10 bolt/D44 frontends fail, yet I wonder how mine plowed snow for 18 years and never had them replaced or greased. Like I'm worried when I've got new ones that are full of grease [​IMG].
    Tim
  14. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    driving on snow doesnt really seem to be a axle strength tester to me, what with being traction limited and all.
    i bought a 12 ton press and it shows some deformation from my u joint adventure
  15. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Well I got the wheel joints out... My company just happened to have a cutting torch so I just happened to borrow it and I get them things out... Now I can continue with my axle swap [​IMG].
