need to know GVWR and GAWR.......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Intense Blue, Jun 28, 2002.
  1. Intense Blue
    Intense Blue Registered Member
    Dec 2, 2001
    49
    i have a 87 k5 blazer 4x4 350 motor, and have restored it and the tags are gone from the door jamb.I'm pulling a travel trailer and i would like to know what the GVWR is and what the gross axle loads are for each axle.thanks.
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
  3. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    why not just take it to a scale and find out for sure?
  4. Intense Blue
    Dec 2, 2001
    49
    i have taken the truck across the scales and i do have those numbers, but what that tells me is the actual weight. I'm looking for the max loads that my blazer can have, and that is called GVWR and GAWR. what i'm wondering is if someone still has the original GM decal in the door jamb that tells you the GVWR and the GAWR for both axles.like i said before i have a 87 k5 with a 350. can anyone help with the numbers that i need? thanks
  5. Intense Blue
    Dec 2, 2001
    49
    i've checked with GM and they don't know, i've looked in all the manuals that i know of.....nothing...anyone help here?
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Hang on, My blazer's out in the Parking lot and it originally came with the towing package. I'll go look......
  7. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    OK, the sticker on the door was painted over and the only other thing that I was able to find was the original "Towing Special" badge on the tailgate that also said GCW 11,000 pounds. I guess that means Gross Combined Weight or something. Hope this helps.
  8. Intense Blue
    Dec 2, 2001
    49
    thanks for the info,but that doesn't really help my situation. i tried calling GM again and they seem to tell me they can not get that info at all.they said if i could find someone with the door jamb decal, that would be my best chance......
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Just to get you in the close ball park, my 78 is as follows
    GVWR 6200
    GAWR Front 3300
    GAWR Rear 3400
    That is with a 1/2 ton d44 front and 12 bolt rear
  10. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    The tag on my '89 says
    GVWR GAWR Front GAWR Rear
    6100lbs 3190lbs 3550lbs
  11. Intense Blue
    Dec 2, 2001
    49
    hey thanks alot...thats the info i needed...super, now i can put my numbers and weights together..thank you
