need to know interchange on SM465- 2wd to 4x4 *DELETED*
Discussion in 'The Garage' started by crossy, Nov 18, 2003.
  1. crossy
    crossy 1/2 ton status
    Jul 12, 2000
    257
    southern ,N.J.
    Post deleted by crossy
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Re: need to know interchange on SM465- 2wd to 4x4
    No . It should have a 35 spline out put shaft , if it is 2WD , and a 1975 4WD 465 should need a 10 spline rear out-put . You can change the shafts out if you want to go into the tranny .
    Good luck , Tom
  3. crossy
    Jul 12, 2000
    257
    southern ,N.J.
    thanx a bunch. DAVE
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    You can change the shafts out if you want to go into the tranny.
    But you would be doing as much work as rebuilding the tranny you already have in doing that. Do you already have a 4 spd or are you trying to convert from auto?
  5. crossy
    Jul 12, 2000
    257
    southern ,N.J.
    already 4 speed
