Need to mount my PRP seat.....mounting brackets?
Discussion in 'The Garage' started by stallion85, Feb 4, 2007.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I have a PRP seat that I am ready to mount into the Beast (84 Pickup), but they do not offer any direct bolt on kits for the seat to the floor. The way the floor is designed looks to make it quite difficult. Is there anyone who sells kits for this or do I have to make something custom. I wish I still had the flat floor like in the K5:doah:
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Just run a couple 1in bars across and mount those to the floor, then weld your tabs to that.
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Anyone have pics of how they did theirs?
  4. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    The seats I bought have sliders so I hit up a local junkyard and pulled the brackets off a big Dodge van. The seat bolted right up but I had to drill more holes in th e floorpan.
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thats' cool, the problem with the trucks are the floor ban has a big hump in it to clear the fuel tank. It originally had a bench seat so I think finding something from the junk yard might be hard.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Sub's are yet again different, but what I did was to build a 1.25" rect. tube frame that bolted vis tabs/brackets to the stock seat mount holes in the floor. I then bolted the sliders to the frame. Can take a pic if you think it would help any.
    You can get "Universal" sliders from most of the seat mfg's if adjustment is desired.
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    It has a slider already mounted to it along with brackets to directly bolt into a K5 drivers seat.
    A pic would be helpful:)
  8. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Angle iron onto the stock sliders and tabs onto the angle iron. I had to weld (if you call it that) some risers on the rear to bring the seat somewhat level. The risers are a little too high. I am going to cut them down a little and reweld the tabs.
    Here are a couple of pics:
