Need Torque specs for lift
Discussion in 'The Garage' started by la_blazer82, Dec 13, 2004.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    I just swapped my rear 10b for a 14bff, added a ORD flip, zero rate, and all new poly bushings. With the exception of the ORD flip, I have no idea what everything is supposed to be torqued down to. Anyone have torque specs for these:
    Rear STOCK springs w/ORD rear poly bushings
    New rear u-bolts for 14bff
    Shocks f/r
    ORD HD Front shakles
    New u-bolts for front D44
    thanks.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ubolts = 140lbs (front and rear)
    ORD HD Shackles = 40-45lbs
    Rear Springs I would guess are around 60lbs
    Shocks I would guess around 40 lbs
    Harley
  3. la_blazer82
    Apr 12, 2004
    148
    SoCal
    Thanks! I didn't find any torque specs with the ORD literature that came with the bushings, and just wanted to make sure I had the lbs/ft rates in the right range.
