Need torque specs quick
Discussion in 'The Garage' started by 4X4HIGH, Jan 23, 2003.
  1. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I am assembling my D60 front and need torque specs for lower knuckle bearing cap bolts and upper king pin cap bolts as well as spindle to knuckle nuts, (the 6 nuts that hold the spindle and knuckle together.) Also just to refresh my memory how to do wheel bearing adjustment properly. IIRC torque inner nut to 50 lbs., back off and then retorque to 35 lbs., add washer and then torque outer nut to 50 lbs. Is that correct?
  2. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
