Need TPI Help Quick....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Nov 13, 2000.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I know this isnt a K5, But my 88' trans am, has a 305 TPI motor. It has starting problems, When I start it when it is cold, it dies out as soon as it starts. This will continue for a long time until the motor warms up then it gets better. I am not sure if this is a TPI problem, or something else. I am not sure what else it could be. Does any one have any ideas what sensors I should check and how? I tried a scanner and it wouldnt come up with any codes. Thanks
    BlazerBoy
    http://generalblueballs.coloradok5.com
  2. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    If you haven't already done so, I suggest you do a complete tune-up first, including new plug wires and a compression check. If this doesn't solve the problem, it rules out a lot of things and gives you an excellent reference point to work from. Good Luck.
    '89 K5 Silverado 4" lift w/BFG 33's
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Sounds like the cold start injector (think you have a MAF system) that may be getting an incorrect signal from the temperature sensor..........check the temp sensor (should be screwed into the block in the front of the engine above the water pump). Let us know.
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
