Need Traction in a bad way!
Discussion in 'The Garage' started by RustBuket, Apr 12, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Alright, I just blew my fund for 35's on a new exhaust and I was wondering if I welded my front 10bolt if it would be a big deal. I know they are wussy axles but I don't wheel hard and the 305 only puts out minimal HP. Also, I have stock sized tires so I think it would be alright. What do you think?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Besides not being able to steer, and breaking your front axle every trip you go out wheeling, traction would be outstanding.
  3. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Get one of them Trunk Monkeys to help you push when you get stuck.
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    You always have a way with words /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  6. RustBuket
    Feb 21, 2003
    1,618
    Thanks for all the words of wisdom...
  7. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Do you have some snow chains? Use them when your offroad. Im from Texas so I dont know anything about snow chains but to me it seams like they would help.
    Nick
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I already have a locking device in my front axle, granted it still releases at times when i REALLY need it, but so far it is going ok, it does do some weird things to the steering wheel when turning, but nothing major. I really don't use the front axle until i really need it, this may help in preventing any broken parts. I was going to attempt installing a spool, but i may just do the welded thingymabopdeal. As long as you know when your hubs are locked, i would say just take it slow when turning, and doo your best to stay off concrete,asphalt surfaces.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Let lots of air out when wheelin and use some brake to slow down wheelspin. It helped me the one trip I went with two open axles right after 12 bolt install (on 31's bald ). I have a rear locker again and with that, low psi, and some footwork in cab its working for now until I get front locker (on 33's now though). /forums/images/graemlins/k5.gif
  10. RustBuket
    Feb 21, 2003
    1,618
    Well since one day I'll probably go 1 ton, I'll have to replace the 10 bolt anyway so I think I may try to weld er up. I also want to find a posi for the rear of some sort but I need to know how to tell if I have a 10b rear or a 12b? Anyone know anything about this? /forums/images/graemlins/confused.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My friend's "Chevy Scout" has the front axle welded.
    On my wheelin' trip Saturday he broke it in the first 10 minutes running bald 40" tires.
    Fixed that one and broke the other side not more than 2 hours later.
    This is not mentioning that he also has damn near no steering ability when the hubs are locked, and unlike an automatic locker, he cannot just unlock the hubs.
  12. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    A 10b has 10 diff cover bolts in almost a perfect circle, with one bolt directly at the bottom.
    A 12b has 12, but the two bottom bolts are across from each other like this ( . . )
    fastest way to tell is to look at the bottom bolts.
  13. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I have a K5 parked out front with a welded 10 bolt and 31s. It's not too bad steering it on dry asphalt in 4wd as long as the vehicle is running and moving. It takes some steering effort if it's parked and you turn the steering wheel while running. A lot of axleshaft twisting and squealing tires. If the motor isn't running you might as well give up and go outside and kick the tires in the direction you want to turn. It doesn't matter whether it's rolling or not. It'll take a while.
    I'm not kidding either. I was expecting something to break between the steering wheel and the steering box because I was trying so hard.
  14. RustBuket
    Feb 21, 2003
    1,618
    Ok guys, here's the thing; I have stock tires that measure about 28" tall. These tires are puny and I think with the minimal wheeling I do it should be ok. But it sounds like this is the way to go.
  15. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Well as far as i'm concerned,,, /forums/images/graemlins/thinking.gif there's only one way to find out for sure, thats part of this "hobby" trial and error /forums/images/graemlins/doah.gif
  16. RustBuket
    Feb 21, 2003
    1,618
    Thats a very good point. I think I will do that as soon as I get this exhaust thing out of the way.
