need tranny help
Discussion in 'The Garage' started by Guss, Feb 16, 2006.
  1. Guss
    Guss Registered Member
    Feb 6, 2005
    78
    houston
    got a used 700r-4 and need to know the difference between the kick down cable on a 90 blazer witch i have and a 92 jimmy witch the tranny is out of
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    they should be exactly the same, if the kick down cable is different just swap them between the tranny
  3. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    92 fullsize Jimmy or a S-15 Jimmy. Either way they both use a "TV" (Throttle valve) cable, its not a "kick down" cable like on a TH350. There should be no difference between those two. Take note that it is extremely important to adjust the TV cable properly or it will slip and you will burn up the trans.
