Need tranny help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stephan.laun, Jan 28, 2007.
  1. stephan.laun
    stephan.laun 1/2 ton status
    Oct 26, 2006
    389
    Abilene Kansas
    Ok i have a 1985 Blazer and it had a 6.2 in it. I put in a 78 350 out of a Camaro. I need to know because I went from Diesel to gas what needs changed in the tranny I know the tourque converter...I found that out the hard way...What else do i need to change.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The governor also needs to be changed.
    It's on the side under a dome cover and easy to change.
    Keep the diesel govenor, I might buy it from you.
    :D
  3. stephan.laun
    Oct 26, 2006
    389
    Abilene Kansas
    You can have it if you want it as soon as i find a new one
  4. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I'll ship you mine from a Gasser 700 and you ship me the diesel one. I will pay both ways.
    :D
  5. stephan.laun
    Oct 26, 2006
    389
    Abilene Kansas
    are they the same? If so its a deal on govenor. Ill let ya know about flywheel...It was in garage now it is gone think my fiancee may have thrown it out.
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Governors are the same size different weights and springs, so it will be as easy as pop out the cover, pull out the governor, slide in the other one, put the cover back on, and you're good to go.
    :D
  7. stephan.laun
    Oct 26, 2006
    389
    Abilene Kansas
    Not enough time
    Well found out today that I am off to the sand box sooner than I thought so quess all my work has come to a end until i return in a year. By then i will hve saved big money to build a wicked trail rig.
