need trans help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kustom71, Nov 8, 2003.
  1. kustom71
    kustom71 1/2 ton status
    Mar 14, 2003
    117
    NJ
    Im driving around today after adjusting the tv cable on my 86k5 w/700r and all of a sudden it dosent want to shift at all.I can get it to shift into 2nd by the gear selector but it wont shift on its own when in OD or 3rd.once its in 2nd it wont shift any further,then when i slow to a stop and start again it pulls but feels like its slipping until rpms get up there or i put it in low then it pulls like it supposed to and i have to shift it again.
    ANY IDEAS???????????
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Maby check the TV cable again. maby the button wasn't all the way out and the adjustment plunger mooved out when you gave it the gas or something. Also might want to check the governor.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Tell us how you adjusted the TV.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    sounds liek cable way too tight. to properly adjust you should hold carb all way open by hand under hood and push in cable housing lockbutton and tighten cable by pulling housing towards rear of truck while simultaneously holding oipen carb by hand and then let go of housing lock button and then let go of carb and thats it, should be done. you dont want cable to pull all the way before carb is all way open or tranny will never shift til waaaaaaaaaay too late,- or never at all if is really pulled too tight(cable)
    the valve body of a 700r4 is practically its brain, and the TV cable and governer are its 'feelers' or sensors
  5. kustom71
    Mar 14, 2003
    117
    NJ
    OK here it goes:I have a TPI engine now so i bought a cable for a camaro cause the blazer one was to short,everything is connected i push in the button and push the cable housing all the way towards the firewall.Then i hook it up to the throttle body and rotate the throttle blades to full open throttle.Thats it!Then when i drive it it sometimes wont start out in first after a dead stop it slips into all the gears not firm at all not even with the gas to the floor.If im driving and floor it the trans kicks down and the motor revs but i dont go anywhere faster it seems to slip.I know it must be bad or im an idiot doin something really wrong!!!!HELP
