need tune-up specs on 454
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spincast375, Sep 13, 2005.
  1. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    Can anyone provide the following:
    timing specs (how many degrees off of TDC)?
    spark plug gap?
    points gap (HEI distributor)?
    Thanks. This engine is not standard Blazer, and I cannot locate these simple numbers.
    Thanks.
  2. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    what year?
  3. spincast375
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    We don't know the year. It is a 76 frame, 84 body, and a 454 with 7,000+ miles on it. We did not install the engine, the po did.
  4. Bigg R
    Bigg R Registered Member
    Feb 21, 2005
    34
    Martinsville,Indiana
    35* Total Advance (BTDC)
    .035 plug gap(points distributor)
    .045 plug gap(HEI distributor)
    There are no points in an HEI!!!
  5. spincast375
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    This shows me what I don't know. Am I in trouble, or what?
  6. spincast375
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    The marker on the face of the block (after I cleaned it) goes from -4* to +16*. Looks like I have an ~'88 block (?).
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    There should be a number on the back of the block (towards the bellhousing). If you can give us that number, we can find out what year(s) that motor is from.
