Need u joint help, Trick 1/2 to 1 ton joint locate or p.n#????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by uglychevyZZ4, Aug 7, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    here is what ck-5 page talks about: </font><blockquote><font class="small">In reply to:</font><hr />
    The 14-bolt (FF) uses a 1350 series u-joint and will not match up to the 1310 series u-joint that the 10-bolt driveshaft uses, so a trick u-joint (1310 on one side with 1350 on the other) will have to be used to accommodate the two different sizes which can be purchased from a parts store or driveshaft shop
    [/ QUOTE ] but i cannot find a part number or a parts person that can find it. i keep getting solt the perfect side for the 1350 side, but the wrong side for the 1310 part. anyone know a napa number?
    I have a 77'gmc jimmy, had 12 bolt, now sitting on a pre-'78 14FF /forums/images/icons/wink.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    5-460x is the spicer number for that
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I use a Napa part # 348 (conversion joint). This is the u-joint I needed going from a 12B to a 14FF, it uses the outside lock rings on the drive shaft.
  4. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    if the 348 doesnt work, try the 447
    mj - thanks for the spicer part # .. i didnt know that they made one, makes sense that they do though.
  5. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Thanks mj, got it /forums/images/icons/laugh.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    spicer makes everything
    there are several pages of conversion joints in the book
