Need u-joint part# for 90 K5 to 14 bolt puhleeze
Discussion in 'The Garage' started by Robert79K5, Jan 25, 2006.
  1. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    Okay so I Got the conversion joint that was listed in the part numbers thread here. I think it was a Napa part 430 or something like that. Well I got it from Advance and they had to cross reference the Napa number. Anyway what they gave me is a bastard joint but it is the wrong size and uses external clips where I need internal clips.
    I am operating under the assumption that they correctly cross-referenced the NAPA part number.
    Does anyone have the correct conversion joint number for a 90 Blazer with a 700R4 and 241 T-case that will mate that drive shaft to a 14 bolt? I would be very grateful. :crazy:
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Wow, this has been covered ad-naseum.. A simple search will get you more info than you need.
    But,
    The correct part number is Neapco 2-1153.
    Advance will have that number in their system.
    John
  3. Robert79K5
    Mar 23, 2003
    335
    Yeah I know, youll see I actually got the first part number from researching a thread on here so I figured someone has run across this before.
    Thanks for posting the number. Ill go by advance on my way home.
  4. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    No prob...
    I'd call advance first.. They usually have to order it for me around here.. 1 day usually.
    John
  5. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
