Need U joint & slip yoke help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Aug 20, 2000.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I need new U joints for my 1979 Blazer. I found Spicers on http://www.napaonline.com
    My front driveshaft has a single U joint in the front and two in the rear, forming some sort of CV Joint. My rear driveshaft has a single U joint on each end. My front axle is a 10bolt and the rear is a 12bolt. I have a TH350 tranny and a NP203 transfer case.
    Can anybody tell me if these part numbers are the correct ones? Or should I get them somewhere else?
    Spicer SPI53147X - Front driveshaft Middle and rear 4wd-3 Joint driveshaft
    Spicer SPI5625X -Trans. or Rear Axle End-2WD-w/3 Spd. MTM & ATM Rear Axle End-2WD-w/4 Spd. MTM & 53.09" Driveshaft Leng. Front Driveshaft-Front-4WD Rear Driveshaft-Front & Rear-4WD-(Exc. 4 Spd. MTM) SNAP-TIGHT(TM)
    Rear Driveshaft-Front & Rear-4WD-4 Spd. MTM
    SNAP-TIGHT(TM)
    Also, can the slip yokes be repaired or must they be replaced? They both have play and would like to fix them now that I'm removing both driveshafts
    My Blazer is not lifted, but will probably lift it 2.5" or 4" someday.
    Thanks for your help.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  2. klier
    klier Registered Member
    Jun 19, 2000
    88
    Faribault, Minnesota
    Hey, did you ever get any responses to this message? If so, were these the right parts?
    Brian
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    The 625's are the strongest, but they are sealed, no zerk fitting. I would go with the 153's they do have a zerk
    fitting.
  4. Blazer79
    1,816
    I only received one email telling me these were the wrong parts and that all 5 ujoints were the same. Fortunately I removed the old ones before ordering and discovered that in fact these were the right part numbers. I ordered them and installed them. No problems so far.
    I left the slip yokes like that because when I removed them I found out that the play was not that bad and the biggest play came from the differentials. I'm changing ring & pinions soon, so that will take care of the problem (unless the play is in the spider gears).
    Thanks for your concern.
