Need VIN tag rivets
Discussion in 'The Garage' started by Eric M., Mar 20, 2005.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I yanked the VIN tag off my 73 GMC for painting and now need to refasten it. I have since found out that screws aren't the best solution since it will look like the VIN tag has beed tampered with. Does anyone know where I can pick up the factory style rivets for a 73 GM (VIN fastened to door pillar)?
    Thanks,
    Eric M.
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Eric...
    This happens more than you think...
    Unfortunately this may not be what you want to hear....
    Once the vin has been altered, removed, or in ANYWAY tampered with in California the vehicle must be inspected by a peace officer, preferably a chippie vin specialist and then it receives a blue chp vin tag....
    It is a crime to possess, use, construct, or otherwise puchase for use any vin rivets, Genuine GM rivets are restricted for sale to OEM only. This is not an appropriate place for me to educate you about vin rivets.
    Does this mean you cant find some at a swap meet... no.. you might be able to... but if it was so easy they would just sell them and people could steal cars easily and revin them (which of course the pros do all the time).. but they try to keep them generally out of the publics easy grasp...
    My suggestion... contact chippie... tell them what you did an ask for their advice...
    Blue tagged vehicles generally fetch a lower price here in cali because prospective buyers are aware there is/was something wrong with the reg/vin on the vehicle at some point... leading most people to believe it was a stolen and therefor possibly abused.... I wouldnt buy one
    "I carry a badge,,, I was a smog nazi... now Im a ck5er"
  3. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    A way out??
    I know of a few guys who swapped rust free cabs onto their trucks,but the cabs came from the junkyard,no title--they got up under the dash with a dremel tool and ground off the underside of the rivets and pried the vin tag out of the original rusty cab,being careful not to damage it or dislodge the rivet heads in it,and used double sided tape or body seam sealer to "glue" it back in place--looks unmolested and still has the OEM rivits in it!--its hard to get underneath the dash to do this though..and technically its still "illeagal"if you get caught--but not many LEO's are too concerned about 20 year old trucks,around here anyway..:crazy: DISCLAIMER--Dont tell them I told you it was ok to do this!!--just telling you what I've seen done before!.:blush:
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    when you remove tag youre supposed to push the pin out of the rivet body so you can save the rivet body and just use a new rivet pin with rivet gun
    that way you dont need new stasr rivet body which are next to impossible to buy cept for one place i know of
    for obvious reasons,,
    another way to do this is to chop backside of rivets off and clear epoxy the tag and rivet heads back in place when done
    sounds liek you already screwed up though
    go to a junk yard and take rivet bodies off a truck or car out there, dont let them see ya do it though
    good luck
  5. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i've never seen a mechanic make sure i had rose style rivets holding on my vin...
  6. dyeager535
    26,982
    191
    Check with Corvette places. I know some sell rivets for VIN tags, I've seen them advertised before.
  7. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Cam, what are you supposed to do then if you cut the dash out and the VIN along with it? Or your VIN plate is actually falling out like it is on my blazer?
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Thats a damn good idea, why diddent i think of that????
  9. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I have made the star style rivets myself...with a cut-off tool on a demel.
    I used the old rivet head as a templet..vise-grip clamped it to a standard rivet.
    then carefully cut-it.
    After hitting the new rivet with a wire wheel...it's ready to use.
    Once the tag is riveted back on...I'll hit it with a buffer.:D
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    IMHO thats not a good idea, it will never look the same, and any cop worth his weight will catch that
  11. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    The info I gave has been around many years..
    I didn't provide it...so guys can steal or dumby-up there rigs.
    It's for the truck restorer...
    that has no choice but to remove tags do to repair rust.
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you didnt learn it from me
    /me draws halo over his head
    and for my required disclaimer to info posted by self above:
    the above info posted by me is solely meant as recreational for helping to expand the mind of the fellow truck enthusiast, and not meant to be used to actually conduct any actions or procedures deemed/ruled un-lawful by any city, county, state, national, or munincipal goverment and/or laws
    nor do i conduct or condone such procedures
    here in IL if a vehicle is suspected to have altered or non original VIN then it will be inspected by a state licensed facility(could be a service station, or a junkyard, etc)and then stamped REBUILT in bright red ink on its title, forever, even after transfers to future owners, i have owned a few rebuilt vehicles in my day including a 77 NOVA i bought and drove out of a junkyard, and a 69 F-100 pickup that went through a junkyard, was a daily driver of mine also,
    good luck :D
  13. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I had a car of mine stolen and the vin was torn up in the process. I had to take the car to the Highway patrol's inspection station where they looked at all the points where there are vin numbers on the car. At that time there were 4 of them. If you are on the up-and-up there wont be anyproblem with it. They would install a new one for you after they make up a new one.
  14. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    well... technically you cant do anything but turn it over to chp and they blue tag the vehicle....
    in reality.... what some of the other posts are talking about is done..... the super clean jobs almost never get caught.... but then you can always get a super sharp copper who would take the truck at the very least... you along with it at the worst...
    I always tell people...
    ok your vin fell off..... or you mistakenly cut it off... but its really your truck... not a "put together" one but just a legit truck.... all the paperwork matches... the secondary vins match... it hasnt been a salvage/reconstruct
    do what you think is apporpriate... why would a copper look at it anyway?
    what were you doing to have him want to inspect it closely anyway?
    but... when you try to sell it you might have a problem... or at the very least pass on this "problem" to an unsuspecting buyer... at some point somebdy:mad: is going to get stuck dealing with a funky vin tag... whether civil or criminally
    if you get caught whatever excuse you have isnt going to cut it.... at least that is what I have seen in my experience.... dmv are bastards with this kind of stuff and dont show leniency
    resto guys are very careful NOT to mess up the vin
  15. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    we look for this all the time..
    instant felony
    they used to have "classes" on this in some of the state prisons here
    "how to be a better thief 101"
  16. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    VIN location
    hey Cam,
    Where are the VIN locations on our trucks? I only know of one on the frame rail, top, drivers side (I think) under the bed. Any others??
    Eric M.
  17. gimpykid
    gimpykid Registered Member
    Dec 20, 2004
    6
    Sunny California
    don't mean to hijack, but is it legal to take a cab from a smog exempt truck and swap it on my 86? It's kidna Changing the VIN, cuz i could register it as the smog exempt one which it really isn't...
  18. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Cam gave the best advice, IMHO. Just take it to DMV and get it inspected, and you're good to go, no worries. Do it right. I have to do the same thing on my 75, as I no longer have bedsides.
  19. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    Cali Laws
    no... it is not legal to swap a non smog cab onto a smogged frame...
    remember the running gear dictates the smog...
    chevy was nice enough to stamp the vin in several places.... partial vin in several places.... but not always on every truck... go figure
    the hidden vins arent hidden at all.... yes the frame.. sometimes on both sides
    When we look at a stolen or "funny" vin we begin at the beginning
    what was the truck supossed to be per the vin....
    what does the model look like
    does it have all the right equipment... tail lenses,engine, trans etc.... do the build dates on sub assemblies match.... what is the DMV history... we can go back and interview all the prior owners to see what they did//or will admit to
    obviously on our trucks getting as old as they are most of this stuff has been swapped around...
    look... the crooks do all the stuff you can imagine
    cut and weld new vins in
    put new stickers on
    rebadge vehicles
    the sano ones slip by....
    can it be done... sure.... Ive said all along you can do it... and you may not get caught if theres nothing funky about you or your paperwork... but somebody sometime is going to get nailed if you mickeymouse your vin in anyway
    blue tag it and be done with it
    Or do what some of the other posters said and pass the problem on
  20. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Perhaps out in Cali where stealing cars/swapping VIN's is more common do police check VIN plates, but I have never had a cop look at mine. I used to have a 86 Blazer with a 77 VIN plate secured to the B pillar like GM did it in 77 with regular rivets. I was stopped quite a few times and never did anyone ask to see the VIN (after a while, the rivets and plate rusted to the point of the rivets blending in with the plate).
    I also was stopped a couple of times with my S10 Blazer on the K5 frame, and still never was asked to see the VIN (and one time it involved about 6 of Annapolis, MD's finest, a broken axle on a semi float rear, and driving home through the city at 2 AM on 3 wheels- they followed the scrapes on the road:blush: ). Maybe I am just lucky, but I think if you are polite, and cooperative, most officers wouldn't really suspect any foal play on our old junk.
