Need wiring help...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Apr 6, 2001.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I purchased VDO gauges to replace my stock gauges, and I'm going to start working on them tomorrow.
    However, before I begin I have a question. Each gauge has its own light, and some have 2. When wiring these up should I wire these in series of parellel? I'm also assuming that the power should be wired the same way (and the ground).
    Thanks,
    Jeff
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Parallel.....if you wire them in series if one burns out they rest will loose power.
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    Thanks a ton for the info...
    Jeff
  4. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Parallel....so each bulb is across 12 volts...
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  5. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    One other thing about series, each light in line will become progressivly dimmer.
  6. Michael
    1,576
    Sherman, Texas
    Actually in a series circuit, if every bulb has the same resistance, the voltage drop across each will be the same so they will all be dim. Not that anybody cares.....
    Michael[​IMG]
