Need your advice!
Discussion in 'The Garage' started by lornyk5, Feb 11, 2004.
  1. lornyk5
    lornyk5 Registered Member
    Jul 17, 2003
    5
    Ontario, Canada
    Ok here is the deal, rough idle and mid to high rpm is powerless!I've checked the main crap like vacuum advance, timing, carb(rebuilt and re-tuned), it is a high km 305 so maybe timing chain skipped but I doubt it, just drove it 400km on an ice fishing trip to lake simcoe.Thanxs
  2. bortz
    bortz Newbie
    Feb 11, 2004
    3
    Alabama
    I would check compression, then decide what to do. Hope this helps!
  3. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    Sounds like your on the right track, Kinda sounds like the chain might have jumped a few teeth, but if you checked your timing and it came up, then hmmm.Easyist way to tell is bring #1 up top and trace your plug wire to cap, pop the cap off and it'l either be on #1 plug or half round off.Other things to check:plug wires, one or 2 may have been rubbing somewhere and have a spot "leaking" fire onto the engine it's self or something close by.One way of checking this I've found easyist is wait till dark, crank your k-5 up and pop the hood, it's pretty easy to see if anything arcing onto something else.Also (with engine off) visually inspect each plug wire for any "burnt or black" spots, this might indacate that it is arcing also.Also could be a plug(s) trying to foul on ya, also check connections to the dizzy (dist.) they could be loose, Could be a vac. line somewhere other that the vac. advance.Could maybe even be the dizzy it's self? (bad pick up or module)? Hope this helps ya out, just offering my $.02.
