Need your opinion on what to do with my Rearend.
Discussion in 'The Garage' started by jays68yak, Apr 10, 2006.
So which option should I go with?
  1. 1
    36.0%
  2. 2
    4.0%
  3. 3
    4.0%
  4. 4
    56.0%
  5. 5
    0 vote(s)
    0.0%
  1. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    A little back ground..I daily drive a 94 k2500 ext cab short bed truck. Its the lighter 3/4 ton so its still 6 lug. In the past few months I have put a new crate motor in, a rebuilt tranny, and now the rearend has blown up. I killed the pinion and everyone of the ring gear teeth and chipped. Im torn between what I should do to fix it. Its a daily driver, 60+ miles a day, and my tow rig for the beater. Currently has a 14bsf with 4:10s and a gov loc.
    1. New Eaton limited slip, new 4:10 gears, master rebuild kit, new axle bearings and seals. $1000
    2. Used gov lock, new gears, master rebuild kit, new axle bearings. $700
    3. Used gov lock, used gears, master rebuild kit, new axle berings. $500
    4. Drop in the 14bff that I have sitting at my parents, already should have 4:10s, its open, would need to move purches, shock mounts, its 8 lug, my wheels are 6 lug. So i would either need to convert it to 6 lug or buy new wheels and then change the front to match.
    5. Trade the 14bff for a 14bsf with a gov loc and 4:10 gears, but the mileage is either 120k or 220k, and it wouldnt bolt in since its from an 88 suburban and is also 8 lug. Could swap the gears and gov loc to my housing. Cost of master rebuild kit and axle bearings. $250.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Use tha carrier that is in it now, and add new gears and install kit. That would be cheapre than all of the options that you listed.
    That is, unless you broke the carier also.
  3. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Ive had issues with the gov loc not locking or staying locked and I figure while im at it might as well go with something new or less use on it.
  4. dyeager535
    26,977
    If the gov-lock has given you problems already, I'd say stay away. My 14SF has issues as well with the gov-lock.
    I'd probably choose the Eaton as a daily driver/tow rig, unless you plan on getting the wheels off the ground, the Eaton should be fine.
    I'd opt for the 800lb spring option, but last I checked they hadn't come out with that for the 14SF yet. I had asked Randy's R&P, but that was over 6 months ago, and I *think* the 800lb kit for the Eaton was supposed to be out by now.
    Of course, now that I think about it more, you have at least two more options for the 9.5" diff.
    Here's one: http://www.traction.eaton.com/prod7.htm Yeah, pricey, but compared to many of the other traction options for the 9.5, it's not THAT much more expensive considering how well that thing works.
    The other is this one: http://www.detroitlocker.com/DT.htm The elocker is leaps and bounds better than this, but this one, with the wheels on the ground, is going to tend to be better than posi. You can still overcome the wheel in the air spinning issue, but it's a bit more involved.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    The title of this thread made me laugh.
  6. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Are you going to do it yourself?
  8. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
  9. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    looks like im going to be dropping the 14bff in. Getting someone to mod me some hubs, then converting it to disc.
  10. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Barring the change to 6-lug (and/or buying wheels), changing to the 14BFF is the cheapest and strongest of the options.
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Pimp it out on a street corner and see if you can make any money. :D
