Needed! 44 ring gear 3.73
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer72, Jun 18, 2000.
  1. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I think that my truck being at the y2k5 meet is doomed ! I got the oil pressure back, I had to replace the crank! I got the rear 12 bolt fixed and the full floater kit on! Along with the wheel studes change out to 1/2 ones that were longer! To night I was going to replace an oil seal on the front axel shaft, what did I find teeth chiped off the ring gear 4 of them why I cant tell the wear patern is good the pinon gear is fine the back lash is good. The gear set is realy in good shape. I dont have the time to replace the set befor the run, I would like to just find a used ring gear to use for now if I could. I plan on rebuild the axel this fall useing a difrent housing which is one more reson not to do it now.
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Dont you need the ring and pinion cause they're worn in as a set? I'm not sure, but I think I can get you a ring gear just about free if that's not the case. Got a friend that runs jeeps and changes a lot of gears in their 44 axles, he's got 5 or 6 ring gears (mostly 3.73) with posi laying around the shop. I'll ask him if he'll part with one if it'll help ya out. Let me know.
    Bryan
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  3. blazer72
    Apr 13, 2000
    939
    KCMO
    Yes you should but I will not spend the time to set up a new set in the axel thats in the truck. I'm think a mised matched set is better then onw with teeth that are chiped. If you can get the set thats fine but the rings fine to.
  4. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    I have a 3.73 ring and pinion and carrier for not much if your interested anyway let me know. thanks
    Brian
    MUDNUT
  5. blazer72
    Apr 13, 2000
    939
    KCMO
    Sounds good to my how much and when can you ship?
  6. laketex
    6,220
    North Texas
    man I forgot all about you, sorry. I'll call dale tommorrow nite (friday) and see if he'd give me a gear for ya.
    [​IMG][​IMG]
    Durant, Ok
