NEEDED: OBA Advise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Feb 13, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I am looking to start learning about what I need to complete my OBA setup. I've had this York 210 sitting on my bench for nearly a year I would guess... I think its time to put it to use.
    #1. I still can't find a BBC bracket to mount this thing... so I will probably fab up my own.
    #2. Tanks? What size tank is best? I figure I will put mine under the bed in front of the axle. I've seen 2.5gal tanks for $72.50 /forums/images/graemlins/eek.gif or 3gal tanks for $29... why such a difference? Is the 3gal too big? Should I just mount it inside the truck to keep it out of harms way? Here are the tanks I am looking at:
    Kilby Enterprises
    3gal no namer tank
    #3. Electrics? I am looking for the "down and dirty" setup... I know I need a pressure switch... and the power switch... I recall seeing a diagram somewhere for this... but for the life of me I can't remember. ???
    #4. Rebuilding my York... should I bother, or just run it as it stands? Is there a way to test these things to see what kind of running condition they are in?
    #5. I am sure I am missing something, someone want to clue me in?
    Thanks all! /forums/images/graemlins/cool.gif
    -Dan
  2. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Found #3 on my own... guess I am just blind...
    Still need answers on the rest though...
    -Dan
  3. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    You will most likely have to get brackets fabed. I have yet to find any, though I've heard some RVs had a York on them.
    I looked at the url for the $29 tank. It appears to not have any fittings. You could try finding a tractor trailor salvage yard and get the air tanks of one for the brakes. I picked up a couple 3.5 to 4 gal tanks kinda cheap that way. You just have to be careful with their size. I had to do some grinding on the tank's brackets to get mine between the frame rails. (have one left over if your interested).
    I contemplated rebuilding my york until I started looking for replacement parts. They can be found, but are a little pricey. Just make sure the clutch engages and you feel suction and pressure on the respective lines. Nice thing is, if the clutch won't engage, replace it. The clutch coil is inexpensive and most parts stores will "rent" the clutch holding tool. It is easy to replace, with the clutch holding tool.
    Good Luck!
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Sounds like you're doing a setup similar to mine. My brackets are being cut out sometime in the next couple of weeks, as soon as my stepdad gets time to use the bandsaw and mill at his work. I mounted my tank in the same place, right under the bed just forward of the axle. The bigger the tank the better, I fit a 6 gallon tank that came off of a semi trailer. The tank is about 10" in diameter, which worked out perfect since I found a real nice way to mount it. I got some strut and pipe hangers for 10" pipe from McMaster-Carr and hung that sucka right in there. The hangers needed to be shortened a little bit but it worked out great.
    There's about 12" of clearance from the tank to the driveshaft, so I'd need to get 12" of compression simultaneously from both rear springs in order to have any interference problems between the tank and the shaft.
    If you want some more pics I have them at home, I can get you the part numbers for the hangers too if you're interested. BTW, the tank only cost $30, which IIRC is a bit less than the 3 gallon from Kilby. </font color>
  5. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    From the look of the pass rear shock in that pic, you aren't getting much more than 1" up travel on that side! /forums/images/graemlins/eek.gif
    Good advise on the tank. I will take a look at the local yard for one there.
    -Dan
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If the shock was attached tothe axle then you would indeed be correct. Good eyes. /forums/images/graemlins/thumb.gif The shock isn't attached onthe bottom though, it's just compressed up so I don't hit my noodle on it when I roll around under the truck. /forums/images/graemlins/grin.gif</font color>
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm on there website now, where did you find this hook image at? I must just be blind lol
  8. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    hook image
    ??????? /forums/images/graemlins/confused.gif ???????
    -Dan
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif I seem to can't type either...The image you posted of how it all hooks up is what I was trying to refer to /forums/images/graemlins/thumb.gif
  10. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    ahhhh... its at the top of the http://www.onboardair.com/ page... says something like, "START HERE" blinking in red... /forums/images/graemlins/thumb.gif
    -Dan
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/thumb.gif Thanks
  12. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    You bet! /forums/images/graemlins/wink.gif
    -Dan
  13. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I think you should go with the Chrome 6 gallon tank!
    Actually, look at some of those cheap "air peg" tanks you can buy at your local hardware store. They usually have a guage, manifold and popoff valve if you are looking at saving money. (another Todd tip)
    You will definately need the pressure switch, check valve, popoff valve and fittings.
    Fab the bracked and install an idler pulley to adjust tension instead of adjustable pump mount. Easier to build that way.
    I lucked out when Todd and I went to Taylors one day. He said he heard there was an aftermarket York setup on some Chevy Vans and we found one with pump, bracket and idler.
    I have the Sun Performance tank in 2.5 gallons but I would think the more the merrier. More storage capacity I believe means the less your pump will kick on.
  14. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Go to the links thread in the beginning of this forum, there is an OBA link and they have all the info and the parts you need.
    I learned everything I did from there.
    As for Tanks, I got mine 7gallon tanks from walmart for $10 each and I am putting 2 under there.
    To me the more the better and at that price why not?
  15. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    We (you) scored big that day!
    I used a 7 gal tank from Home Depot. For like $17, it had the 150psi pop off and gauge.
