Needed...
Discussion in 'Pacific Region' started by pvfjr, Mar 14, 2005.
  1. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    52" 1/2 ton springs in good shape
    Stock U-bolts for the rear
    NP205 stick and mounting bolt in any shape
    10-bolt with 3.42's for an s-10. 7.5" ring gear?
    Now I know you guys have a lot of junk sitting around, willing to get rid of it for a few bucks?:dunno:
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    i have a set of 52's and a 10 bolt rear, i'll check the gears.
  3. grundy99
    grundy99 1/2 ton status
    Sep 13, 2004
    389
    Loveland, CO
    I have a 3.42 10 bolt rear sitting here.
    It is out of a fullsize though. I dont know if that will work or not
  4. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I have a set of USED u-bolts from my 12 bolt. They were installed for almost a year and are long enough for 3" blocks so you would need to cut them down a few inches.
    $10. for all 4 and I'll even toss in a set of spring plates if you want them.
    Make it $15. and you can have the blocks too. :D
  5. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    I think for now we're going to try to look for a direct replacement. We might go full width, but we'd have to know the difference in widths first. If anyone knows that would help. But first, I think we are going to look for a 5 lug s-10 style 10 bolt.
  6. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    I have a van wiidth 5 lug chevy 10 bolt if you want it 342s
  7. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Would the perch width be the same? How much wider would the axle be? Spring under or spring over?
  8. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    spring over im not surte the measurements on the perchs I also have the stock 52s that came out of the van with the axle and the total is i belive 3 inchs wider than a regular fullsize 10 bolt. the perches will probably need to be moved but i can take care of that for a little $ if needed
  9. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Hmm, wider than full width might be too wide for us. We're trying to keep it simple, we'll mod the thing later. For now, we're just trying to get it running so it can be inspected and registered.
    Are those 52's the same as one I'd find in a truck? I wouldn't want to get screwed up with different thicknesses or eye size and such. If they're the same, I'd be interested. I'm just looking for direct replacements, as I broke one of mine. Just wanna swap them out and replace the block with a shackle flip.
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    52;s are in great shape, 10 bolt is out of a camaro which is an s-10 swapable axle.
  11. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Any news on those gears yet?
  12. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    the van width is the makes it the same width as the front tires would be and the springs are a little different. they are still the same length but there is one less spring so you get a softer ride. it sounds like jeremy might have a better set up for you but he is a ways away.
  13. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    The same width as a full size front? This is a S-10...
    I've got a friend headed to Eugene for spring break, so maybe his springs would work out after all. I'm wanting to go with a stock replacement springs for my broken ones and a shackle flip, maybe a flipped overload too. It would be nice to get rid of those blocks.
