Needing another schematic... Underhood.. alternator etc...
Discussion in 'The Garage' started by rocko, Jun 1, 2004.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    I am restoring the wiring harness on my black/gray 89k5... In the process... I've removed a poorly installed GM Security system and man.. there are too many "stray" wires under my dash and hood.. I was wondering if anyone has the schematic for underhood/under dash to include starter/ alternator/ fuse block for a 89k5...
    Here's what's happening... my battery is getting drained at a rapid rate..
    New battery and alternator just installed..
    Something is draining it.. I want to redo the wiring.. cause when I turn on my turn signals.. I can watch the amp gauge pulsate with the turn signals.. and my ac will drain my alternator at a rapid rate also.
    Any help is greatly appreciated... /forums/images/graemlins/thumb.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Before you get too far into it, cheeck the voltage at the battery, with the engine running. It should be in the 13.8-14.2 volt range. Then start turning stuff on, lights, a/c, wipers, etc and watch the voltage. If it drops below 13 volts then your alternator just isn't putting out enough juice to keep the battery charged. /forums/images/graemlins/cool.gif
  3. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks Harry... I had the battery checked at work, shows it's putting out low output.. when my battery was charged, it was fine.. I believe the alt is draining my battery. And when I turn on my turn signals.. I can see the amp gauge needle be in sync with the turn signal clicking.. is this a sign of my alternator also? or something more indepth ?
    This is a brand new alternator also... do these things go bad right out of the box? /forums/images/graemlins/shocked.gif /forums/images/graemlins/thumb.gif
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Rocko, check my webshots, I believe I have some more diagrams there /forums/images/graemlins/thumb.gif
  5. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Too the top.
