neeed heellllppppp
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ROCKBUGGYK5, Mar 27, 2001.
  1. ROCKBUGGYK5
    ROCKBUGGYK5 1/2 ton status
    Jan 2, 2001
    170
    TEXAS
    hey guys ive got a little problem, i keep breaking the centering pin on my driverside leafspring, it breaks on the trail and i lose steering due to the fact when i turn the wheel the axle just sides forward and back on the spring and the tire just goes where it wants, i made sure the u-bolts were tight the second time so i dont think thats what caused it, by the way it has a dana 60 frontend and 38.5s sxs with a lockright up front the springs our tufff country4 inch hds with ord shackles, so what is causing this and how can i keep it from happening again
    thanks
    adam
    ROCKBUGGY K5 38S LOCKED AND CHOPPED
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Do you still have the leaf clamps on it? If not, that could be the problem. Other than that, I have no idea.
    I gotta ask about a lock-rite (sp?) in a D60. I thought there was no such animal.? I’ve been told more than once that a full carrier LS or DL was the only option.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  3. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Loose u-bolts are the only thing I have ever seen do that. How new are the nuts? Do they have the nylon locking ring/is it old or used more than once? I'd get new ones! Steve
  4. ROCKBUGGYK5
    Jan 2, 2001
    170
    TEXAS
    yes the do make a lockrite for a dana 60 anyplace will carry it, also im a litte guy i guess i didnt get them tight enuff because they are brand new u bolts, are yall sure theres nothing else that could cause this problem???????
    adam
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    For something as important as U-bolts, you really need to be using a torque wrench and not the "I think it's tight enough" method. If you're not torquing the nuts enough, that could have something to do with your breakage problems.
    [​IMG] Semper Maintenance!
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Are thre enuff threads on the u-bolts? That should be dead space and have no movement.
    Twiztid
  7. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    Use an allen bolt to replace the pin i think it was 3/8" shank with a 1/2" head i had to do this to one of mine, seems to be a stronger bolt.
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
