neet buggy on ebay
Discussion in 'The Garage' started by sweetk30, Aug 6, 2005.
  1. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
  2. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Ya it seems like a good jump in and go rig. :D
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Looks like a good source for parts...
    That is a nice winch by the way.
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    That's what I was thinking. Axles, winch, tires.....
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Why does it have an A/C compressor?
  6. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    good point.
    maybe onboard air, i felt like he was rushing when writing that, like it was last min or something.
    maybe he just want to be cool on the trail
  7. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    i'd change the motor for a 350 and lower the gears to 5.13s. spool the rear and call it done.
    i'd drive that. it looks fun. unless there's some big mechanical problem i'm missing. :crazy:
  8. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Jesus H. Christ... that is a long paragraph w/o one period...
    it has a 305 tpi injected motor out of 1986 trans am runs good has a little bit of a valve noise probably needs adjusted {not motor knock just valve noise}has auto trans turbo 400 it has 4 inch lift springs hydro boost brakes like on older 1 ton chevy has a fuel cell with a working gas guage all the offroad lights you'll ever need front and rear 2 electric cooling fans on seperate switches with both on you 'll never over heat has a newer radiator as well it has new in line high volume fuel pump from summit racing has 4:11 gears front and rear welded in the rear for traction never locked front because with the 44 x18 x16.5 tires witch we custom grooved similer to the bfg crawlers i never needed a locker in this rig most of the sensors on motor are new including 300 doller mass air flow computer is mounted in military ammo box buggy has a 12000 lb warn winch that has been used 3 times 1 to pull buggy which had a flat 1 to pull itself up into tree so i could change flat and 1 to pull a huge stump out here at the house cable is rusted looking but winch is 1 year old and barely used that was 1100 dollers it has a 14 bolt rear end and a dana 60 front end no broken axles here you can rip as hard as you want and it doesn't break!!!! the cage is all heavy duty solid so if you roll your good to go racing seats with padded covers and 4 point harness keep you in i;m sure i'm forgetting alot but if you have any question call me at 330 323-9008 will entertain offer's and trades i also have a 95 grand cherokee lifted 8 in with v-8 winch 35's {dasily driver} and a 91 wrangler 6 in coil spring conversion with 36's and a long list of mods i may trade 2 or 3 for the right 4x4 turbo diesel truck
  9. bigjbear
    Feb 18, 2000
    13,973
    454
    Marietta GA
    That's what I was thinking, too. Someone must have slept ALOT in grade school.
