negative battery cable
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by pornorob, Apr 29, 2002.
  1. pornorob
    pornorob 1/2 ton status
    Jul 12, 2001
    215
    ;jkl;
    where am I supposed to attatch my negative battery cable in my 72 CST, I just finished the rebuild on m engine and Ijust can't remember where the heck I took it off from ....Thanx
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It goes to the engine block. It doesn't really matter where...I think mine goes on with the AC compressor bracket.
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
  4. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Which side is your alt. on?
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Mine, and every other one I have seen in the '70 - '72 era goes to the tapped hole in the front of the passenger side head that is closest to the battery. The alternators on these trucks are on the opposite side of the engine from the battery.
  6. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Mine is in the same tapped hole in the front of the passenger side head. I believe that my motor is out of a '73 or '74.
  7. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    As long as you have a heavy guage ground from the battery to the engine block, you will be alright. Make sure the connections are clean and bare metal. You can paint over them afterwards for clean appearance and corrosion prevention. Also make sure you ground the frame and body to the engine block or straight to the battery.
