neon and wiring to amp turn on
Discussion in 'Audio' started by zcarczar, Apr 27, 2002.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Is there anyway i can wire a neon light to turn on when my amp turns on? i thought maybe using the amp remote turn on like somehow
    Thanks in advance
  2. Prembird
    Prembird 1/2 ton status
    May 15, 2001
    811
    kc, mo.
    The remote turn on for you amp will not supply enough power to the neon for it to work properly... Are you just wanting to light up a single neon stick when you turn the amp on or are you talking about undercar neon?
  3. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    You need to get a relay and run it like so
    Pole:
    87 positive output to neon
    87a not used
    30 positive fused from battery
    86 ground
    85 connect to remote wire on amp
    Then just ground the neon bar ;-) Let me know if you need anymore help. You can find a relay at radio shack or any car audio shop for about 1.50
  4. zcarczar
    Feb 10, 2002
    2,495
    Thanks, ill be sure to talk to you when i get the neon
  5. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    No problem ;-)
  6. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    I am a Streetglow and Liteglow dealer, Need anything?
    Tony
