neutral on transfer case?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Marshall, Dec 26, 2002.
  1. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    what is the neutral on the transfer case used for. im not sure /forums/images/graemlins/confused.gif.Thanks for any help provided.
    350/208/3.73Gov-Lock/31's/10Bolt
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I think it's for when you use the PTO (power take off). You remove a little cover on your transfer case and gain access to a gear where you can attach a winch or the pump for a snowplow, water pump (military) or maybe a corn grinder /forums/images/graemlins/wink.gif
  3. Marshall
    Apr 8, 2002
    204
    LiveRmore,CA
    theres no other uses for it that anyone else knows about?
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That's about it. That and for when you're flat towing the rig. /forums/images/graemlins/cool.gif
  5. SickboySS
    SickboySS 1/2 ton status
    Nov 24, 2002
    154
    Auburn Ma
    its good when you blow a u-joint cause it stops the shafts from spinning and doing damage
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    use caution flat towing in N
    shafts spinning and gears not could equal burned bearings
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yeah, in the owners manual they tell ya to stop every 200 miles and drive with the t-case in gear for a mile or so, to lube everything back up. Like that's gonna happen! /forums/images/graemlins/wink.gif
