neutral safety switch help
Discussion in 'The Garage' started by adamforsythe, Apr 21, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    How do I hook this up to my B&M Megashifter? I don't know where the wires are. what color are they? HOW DO YOU DO THIS???????
    I thought the switch was part of my back up light switch. The only wires going to that switch where my back up lights (Blue/green wires). I have those hooked up to my shifter and they wrok. Where is this stuiped thing?
    Adam
  2. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Is this for the stock shifter? If so, I droped my colloum down to reach it better on my 91' pu. I think it should be the same on the older style too.
  3. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    I have a first Gen. and have the same problem, mine is a purple wire and is supposed to be at the base of the column on the firewall. Any way that is what my wiring diagram says... Later J.
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    The only thing that I have found is the back up light switch and the KEY Ignition switch. But no safty switch.
    Adam
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the NSS is the half moon thing on top of the steering column near the fire wall. the NSS wires are purple/purple with white stripe. i think it has the reverse light switch in it also, but not sure
  6. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    yellow and purple
  7. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    That half moom looking thing by the fire wall on the colum ONLY had a green and blue wire. They where for my back up lights. I have all ready yanked those wires and hooked them into my shifter. There where no other wires are prongs for wires on that half moon looking thing.
    Adam
