Neutral safety switch on 72
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by cheyenne10, Feb 4, 2003.
  1. cheyenne10
    cheyenne10 Registered Member
    Jun 14, 2001
    79
    Oregon
    We just swapped in an TH350/NP205 in place onf SM465/NP205. I need to
    hook up the neutral safety switch with kids around. Does anyone have good advise on how to wire this switch?
    email me at bob.hines@eweb.eugene.or.us ro reply to this post.
    Thanks.
    /forums/images/graemlins/truck.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    did you swap for an auto column ?
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    In 1st gens the NS switch is in the column down by the firewall along with the backup light switch too. /forums/images/graemlins/thumb.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You could put in a floor shifter from B&M...they have the switch in them.
  5. Blazerholic
    Blazerholic Registered Member
    Jan 12, 2003
    77
    Latonia,KY
    /forums/images/graemlins/confused.gif I thought they only had the reverse light switch. They have a neutral safety too??
  6. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  7. cheyenne10
    Jun 14, 2001
    79
    Oregon
    I put in a stock 72 tilt column into my 1st generation truck.
    I have the backup/neutral saftey switch at the lower end of column. I just need to know how to wire it up like stock.
    Any more tips?
  8. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    You need to find a stock wiring plan and see what's diferent between the manual trans and auto trans trucks. As the 1st gen didn't have a clutch switch like the later ones did. /forums/images/graemlins/confused.gif
  9. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    You'd probably be better off getting to the yards and getting an under-dash harness out of a '72 with an automatic. If you need to meet emissions testing, you will also need the under hood harness so that the TCS will work.
