new 350, loose over 1 qt oil between oil changes.
Discussion in 'The Garage' started by ChevBlazin, Mar 31, 2003.
  1. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I bought a gm goodwrench 350 almost three years ago, so it is'nt exactly "new". However it has about 25,000 miles on it now (the warranty is 3 year/ 50,000 miles). From what I remember even right after I put it in it seems like It will be a quart low on oil (valvoline 5w30) after about 2000 miles. I get a puff of smoke some times when I start it too. It doesnt leak oil anywhere except for a very tiny bit by the valve covers (doesnt make it to the ground though) I have an edelbrock performer intake, edelbrock 600 carb, and headers on it, besides that it's a stock motor. What would cause me to loose this much oil, is it normal? and the warranty has 2 months left, do you think it will be covered even though it has the aftermarket parts on it, I didnt do any internal changes on the motor? Any ideas, suggestions would be great.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I dont think using a quart of oil between changes is bad.
    I really doubt if they will warenty it. I think that is considered acceptable oil consumption for a 350 in a heavy vehicle.
    My 350 has always used a quart between oil changes(2500- 3000)
    When its a quart down I always know its about time for a change.
  3. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    When you get to a quart a week, then start to worry /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif that's when mine finally started a wicked death knock and then seized. /forums/images/graemlins/tongue.gif
  4. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I would not worry, that is about average. My 96 Z-28 with a LT-1 350 would use a quart every 3000. The little of smoke when you start it up is the valve guides. This is a normal thing for chevy engines. What causes it is that the valve guides when the engine is sitting allows a small amount of oil to seep into the cylinder. I see nothing to get concerned about. /forums/images/graemlins/thumb.gif
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I agree
    John [​IMG]
