New 4" lift, now steering problems! HELP!
Discussion in 'The Garage' started by 86haubs, Jun 12, 2006.
  1. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
    After fighting with the lift and brake lines, I finally got everything squared away, just have to bleed brakes. Now I have a new issue....My steering will not turn full right lock. I think I need to adjust the drag link, can I do this without any reprocussions? I just got an alignment like 3 months ago, so I know it it good. If I just pull my drag link off with my wheels straight can I center up my gear box, then adjust the link and hook it back up? That is my plan, but I am uncertain of the results! HELP!
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    You need either a drop draglink, or raised steering arm.
  3. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    I forgot to mention I did get the new arm.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Yes, you will need to adjust it. You have moved the knuckle farther away from the steering box.
  5. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    The steps I am planning to do in my head, will that work w/o any negative reprocussions?
  6. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    yes, just make sure you count the turns lock to lock on your steering wheel to get it centered
    If your alignment is warrentied go get it redone if you can...... just don't mention you just put a new lift under it
  8. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    I thought about that, but I think the "new look" will give it away. Thanks for your help.
