New axles or gear swap??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bennevis, Oct 19, 2000.
  1. bennevis
    bennevis Registered Member
    Mar 28, 2000
    41
    Colorado
    I have an 82' with 32x11.5's 10bolt front and rear with 3.73 and a 700R4. Was looking to go to 4.10 with 30 spline axles and was quoted about 850 from Randys R&P and WCD. This included front and rear gears install kit, spider gears and rear axles. I have a guy who is willing to sell me a complete Dana 60 and complete 14Bolt FF, both with 4.56 gears for $1000, maybe less. I do not do serious rock crawling or anything like that but occasionally like to get out in the mountains to do some fishing. Would the axles be overkill or is the price to good compared to just changing gears to pass up? How would the 4.56 do with 32 tires? It would be nice to use the overdrive again here in Colorado on some of the hills along the highways. Opinions and advice welcomed. Thanks Bennevis
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If you just plan on using the truck for fishing and light off-roading, the 14-bolt/Dana 60 combo is probably overkill, though $1000 for both may be a decent deal (depending on whether they need rebuilt or not). Just remember, the last single rear wheel Chevy that used the Dana 60 solid front axle was built over 10 years ago, so regular wear items such as brake pads, calipers, bearings, u-joints, and the tme and labor could add several hundred dollars on to that price in a hurry.
    Also, if you do decide to stay with the 10-bolts, I would highly recommend upgrading to a good aftermarket limited slip diff in the rear.
  3. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Get the one ton stuff and never look back. Sell you pair of Camaro 10 bolts for about $500 and you've re-couped half your money!! You can never be too overbuilt!!!
    ken
  4. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    That priced included the labor also I assume? A thousand dollars for both sounds like alot for both axles if they haven't been rebuilt. I bought a 14 bolt full-floater and and 3/4 ton Heavy Duty Dana 44 ( I was told by a guy that worked on my front axle that it was a H.D.) I paid $350 for the pair but they both needed all the brake hardware replaced including the very expensive rear 14 bolt drums. To sum it up, if you can find out if they axles were recently rebuilt than that would be a great deal, even if you only do mild wheeling.
    Dazed and Confused in a 74 Blazer
    Zeppelin
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    If you're going to pay someone labor to set up the ring and pinions, that will add at least $500 to the cost of your 10-bolt upgrades. You might want to consider swapping out your 10-bolts for a different pair that already have the right gear ratio. To find them with 30-spline might be tough, though, because I think that the front one was only offered for 3 years.
    '85 JIMMY
    '90 paint/grill/trim 5"susp 33/12.5/16.5
    Fresh 350 B&M '87 TH700
  6. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    The labor shouldn't cost more than about $150 per axle to set up the gears (at least that's what the standard seems to be around here).
    I would stay with the 28 spline axles in the front 10-bolt strictly based on the fact that 30 spline front axles are very hard to find, whether they are new or used.
    For the price on the 14 bolt/ Dana 60 combo, a junkyard 14 in good shop goes for around $200 - $300 around here. Dana 60's are a little tough to come by and therefore go for a lot more than the common Dana 44 3/4 ton front end. Boyce sells rebuilt 60's for around $1,500.
  7. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Are you not happy with your setup? I have the same trany and 3.73 gears in my 1990 burb w/ 31" tires. I' thinking of getting 32" tires and a 2" lift. How does OD work for you? Right now I have good power with the 31's just want a little bigger but still want to be able to fly up mountian highways. Thanks.
  8. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Man, $1000 for both D60 and 14bolt sounds like an awesome deal. I agree with Ken, get them and never look back. Too much Beef is the right amount of Beef. With 32" tires and 4.56 gears, your RPMs will be pretty high though at high speeds. I would go 35"s or at the least, just step up one more inch and go with 33".
    Zepplin, 14bolt FF plus D44 for $350 sounds like a good deal, but you have to remember, that the D60 front are worth more than double $350 regardless of condition. Atleast that seems to be the norm. I don't think it should cost that much, but with all the hype about them, that's why the prices are jacked on D60s, not to mention they're hard to find.
    Boss
    http://www.boss.coloradok5.com
  9. bennevis
    Mar 28, 2000
    41
    Colorado
    Thanks for all the responses. There seems to be a question as to wether the axles are rebuilt or not. The guy that is selling them says that they are rebuilt and complete with brakes and hubs. Does this change anyones opinion on wether this deal is any good? Thanks again
    Bennevis
  10. CK5
    May 19, 1999
    21,622
    701
    CO
    Where in Colorado? If you decide not to get them, I will buy them like yesterday for sure, and I am in Colorado. Send me a private email.
    5,000 Pounds of American Rolling Steel
  11. bennevis
    Mar 28, 2000
    41
    Colorado
    shum1, the power that I have is decent if you are on flat ground. When I get to hills like Monument, forget it. Especially in OD. It will shift from 4 to 3 on hills so I do not use it. Hope this helps.
    bennevis
  12. CK5
    May 19, 1999
    21,622
    701
    CO
    Oh yeah, if you go to 1-tons you will need new tires and 8-lug wheels as well.
  13. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    If you do the axle swap, you'll also need "trick" rear driveshaft yoke, 14FF and D60 ubolts, spring plates, and backing plates from a 88-91 3/4 Suburbarn (SF 14 bolt) for your e-brake cable.
    Shawn
    87 K5
    http://www.off-road.com/chevy
  14. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    R U saying that the backing plate from a SF 14 bolt (88-91 vintage) is the same as a 14 FF...meaning they will interchange??
    ken
  15. Shawn
    1,753
    5
    5280'
    Yes, but I'm not going to bet my life on it. This is what Steve Fox did on his so he could retain his stock e-brake and cables. The salvage yard guy (we call him axle d*ck) didn't give us the application since he didn't want to give away his "secret" but after looking at other SF 14's, these look to be the ones and are the same dia. I think the application goes down to 84 so it would be 84-91.
    Shawn
    87 K5
