New Axles?
Discussion in 'The Garage' started by 80' 427, Mar 5, 2007.
  1. 80' 427
    80' 427 1/2 ton status Premium Member
    Nov 14, 2006
    4,089
    400
    NEBRASKA
    I am driving my 84 K-10 to moab in may and after talking with off road design I was told to get greaseable shackles, steering box brace, and sway bar disconnects. They also suggest I get some spare axles for the rear and maybe some spare fronts. Should I just buy new stronger axles or see what I can get used? I know I know I should get a 14 and 3/4 8 bolt hubs but for NOW I am going to leave it with front and rear 10s and someday maybe it will be get 3/4 stuff. I only run 33s and don't plan on a change cause its my daily driver. It is locked in the rear and front trutrac so it may be harder on axles. What do you guys think, besides I should get the 14.
    John
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Make sure that your front u-joints are in good shape. Get some spare rear shafts and run it. No reason to worry about swapping axles with 33's.
  3. 80' 427
    Nov 14, 2006
    4,089
    400
    NEBRASKA
    Thank you, for your quick answer. Thats what I was hoping for, the front u-joints were just replaced.
  4. 80' 427
    Nov 14, 2006
    4,089
    400
    NEBRASKA
    I bought new superior axles to be on the safe side. Now I will have the factorys for spares. I also bought a steering brace, greasable shackles, and sway bar disconnects from off road design. Now to get some spare front axles and I should be set for moab. Some day it will get 3/4 ton stuff so it will take the work on the farm.
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    1 tons, 5.13s, detroits.
    j
  6. 80' 427
    Nov 14, 2006
    4,089
    400
    NEBRASKA
    I am sure someday. I drive a 11 second big block full roller street car as the alternative daily driver to this truck. Some day it will be crazy for now it will be a short so I can use the bed on the farm. Besides in the mud drag class I am in I cannot run more than a 34" tire.
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    what locker do you have in the rear? Is it a full repalcement locking diff or just a lunch box locker?
  8. 80' 427
    Nov 14, 2006
    4,089
    400
    NEBRASKA
    detroit
  9. resurrected_jimmy
    May 23, 2005
    2,241
    with the advise given above and the list you of items you put in your orignal post I would say you are set up for a good week.
  10. 80' 427
    Nov 14, 2006
    4,089
    400
    NEBRASKA
    Good, I guess I think I will have more fun without having to worry about breaking every time I turn around. I will be cautious but would still like to be able to push it a bit.
  11. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I have 3/4 ton axles under my K5 and it only cost me $400 bucks installed. All i have to do now it get a Detriot and mabe some Chromlys.
    BTW: this is also me DD
  12. 80' 427
    Nov 14, 2006
    4,089
    400
    NEBRASKA
    I understand it isn't that I don't want to get a 14 it is just when I built it I was stupid. I bought the good parts for the axles I had so I am going to keep them a while. If I did it over I would buy a 3/4 right away.
