New Ball Joint Zerk fitting contacts Axle Shaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83k5blzrbob, Dec 15, 2006.
  1. 83k5blzrbob
    83k5blzrbob Registered Member
    Aug 7, 2006
    40
    3
    Waterford Michigan
    Anybody ever run into this.....I installed new greasable upper and lower ball joints on my 83 K5, and when I spin the axle shaft it slightly contacts the end of the zerk fitting on the upper ball joint.
    Any ideas for a solution, should I remove the zerk after greasing and then plug the hole till next grease job?
    Appreciate any ideas........
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Sounds like you replaced them with the wrong size (too long) see if your local auto parts store has the right ones for you? :dunno:
  3. 83k5blzrbob
    Aug 7, 2006
    40
    3
    Waterford Michigan
    Thanks for the reply, I assume that you refering to the wrong size zerk and not the wrong size ball joint........with that said, I think the zerk couldn't be any shorter or the gun wouldn't attach.
    Any other ideas? Are most replacement ball joints greasable?
  4. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Most replacement ball joints are greasable; however the bottom one you can leave the zerk in, only to be broken off by a rock, and the upper on will be brocken off by the axle shaft. Grease them well, and remove the zerks and replace the little plugs that came with the ball joints.
    Next time you do brakes/wheel bearings, it would be wise to take the spindle off to inspect the spindle bearing, and grease the ball joints again.
    Jimbo
  5. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,236
    284
    San Jose, California
    I had the same problem. Next time get Moog balljoints since they have the grease fittings in a different place so you can grease them without plugging the hole after.
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Go to your local parts store and buy some "recessed" fittings. You'll also need a grease needle to use them. I have them on my front axle u-joints and they work like a charm.
