New Battery -- No start
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PaulMahon, Jan 6, 2003.
  1. PaulMahon
    PaulMahon Newbie
    Dec 22, 2002
    4
    I dropped in a new Optima battery...while installing and tightening the Positive cable, I allowed the ratchet to touch the frame and start-a-"sparking". Now, I have no headlights, no interior lights, the starter turns over fine, but no ignition. Oh yeah, ALL of the fuzes under the dash check good - not one of them is burned out.
    Any thought from the field??? /forums/images/graemlins/confused.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You might have burnt the fusible link.
    I don't know exactly where it is, but you will only know if you test it.
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Check for the fusable link on the firewall between the heater and distributer.... /forums/images/graemlins/thumb.gif
  4. unsane
    unsane Guest
    check the small wire from the positive side og the battery to the alternator and make sure its tight! That controls all your computer stuff. Also check your ground.
  5. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Along with the fuseable links on the fire wall don't forget the ones on the starter as well.
    Eric
  6. PaulMahon
    PaulMahon Newbie
    Dec 22, 2002
    4
    Excellent advice from all....thanks again. Oh yeah, It's an '89 model. Once again, ColoradoK5 comes through with expert advice.!! /forums/images/graemlins/cool.gif
  7. dyeager535
    26,975
    Yep, check the fusible links. Theres a "junction block" for the fusible link (power) leads on the firewall, towards the drivers side top, black piece of plastic, all red wires going to it. You can check voltage there.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Just an FYI for the next time.... ALWAYS install the positive battery cable first. Then no part of the truck can complete a circuit to ground while you're tightening the clamp. /forums/images/graemlins/cool.gif You only have to avoid the negative post(s) on the battery.
  9. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    could be one of ur fuses under the dash also...check em' all to make sure
