NEW Beadlock Pictures LOOK
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazr77400, Oct 8, 2001.
  1. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Check out the Pictures of the Custom Rock Ring and Custom Beadlock Rings.
    <a target="_blank" href=http://community.webshots.com/user/blazr774001&gt;http://community.webshots.com/user/blazr774001>http://community.webshots.com/user/blazr774001&gt;http://community.webshots.com/user/blazr774001</a>
    4 wheeling is like sex, when its good, its really, really good, when its bad its still pretty good.
  2. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    Re: Beadlock Pictures
    very nice work! i only wish i had the time and resources to do that stuff.
    MTPockets
    ps. will you be able to lock the hubs still?
    <a target="_blank" href=http://coloradok5.com/moneypit.shtml>http://coloradok5.com/moneypit.shtml</a>
  3. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    There is just enough room to put the Hand in there.
    I will have to mount the wheel and tire and then add the ring later. I made it so only 8 of the bolts hold it on. It kind of also works as a theft deterent. If some one tries to steel it, most likely the other 8 bolts will break and the tire will pop off and whap them in the face.
  4. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    whoa that's crazy looking. MORE DEATAILS Please!!!! Material, what you used to cut it, type of wheel you're mounting it to....
    Sherman, Tx
    <font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
  5. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    I started with a 4'x4' piece of 1/4" 6061 aluminum. Then I cut 4 16" squares out of it with a Bandsaw. I then stacked each one on top of the other on a CNC mill. I drilled the 8 holes that hold the ring on. Then I seperated them and made a fixture that would let me bolt down each one. I then started with a 1/2" 2 flute carbide endmill. I then ran it around the piece to get the outside diameter and the clearance for the other 8 holes. Then I went to the middle. I cut the Bowtie then the Banana looking deals.(Brake cooling system LOL) I then went around everything once more to get a good finish then cut a .130 radius around every sharp edge. It took about 2 hours for the first one and then about an hour each other one. I just need to get them polished for the finishing touch.
  6. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    The ring is on a 15x10 eaton Bead lock. I am going with the 38x14.50-15 tst/sx.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Clicky.........'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com
  8. laketex
    6,220
    North Texas
    hell yeah man. I've done quite a bit of work on a mill but no access to one now. it's on my list of big boy toys when I get out of school and get my own shop. That looks awesome. Good to hear you did the work yourself!!!
    Sherman, Tx
  9. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    Yeah, the CNC Mill I did it on Cost about $100 Grand. We have 6 of them at my work. Just wish it was all mine so i could work on it 24/7.
  10. laketex
    6,220
    North Texas
    yep i hear ya there. I'd be very happy with a BP manual mill though. Maybe a Clausen lathe just for kicks. Oh cant wait till i'm outta school!!!
    Sherman, Tx
