New bearing, should i do new races??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wakedog, Dec 10, 2001.
  1. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    Well im putting new wheel bearing in, i got the old races out of one rotor and got the new ones in, but it took me a while so i was wondering if i can leave the old races in the other side, they feel perferctly smooth and not knicked. Should i put the new ones in or not??
    <a target="_blank" href=http://www.bigredjimmy.iwarp.com>http://www.bigredjimmy.iwarp.com</a>
  2. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I always install bearings with new races usually a matched set on my vehicles and my aircraft. I'd loose my licence if I didn't. [​IMG]
    James
    jimmy79@shaw.ca
  3. wakedog
    Mar 7, 2001
    233
    Minnesota
    Well i did the other rotor, this time they came out a lil easier so it wasnt so bad. Thanks.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I always replace the race when replacing the bearing. better doing it at home than out in the middle of nowhere.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  5. Slayer
    Slayer 1/2 ton status
    Oct 17, 2001
    225
    Eastern Colorado, jokingly referred to as Western
    Yup, it's really worth the money to replace the bearings with the races. In most cases the old races will have some scoring and glazing, and this could prematurely wear out your new bearings. Spring the extra few bucks, you'll be glad in the long run.
    <font color=blue>I don't know everything, I just think that I do.............</font color=blue>[​IMG]
  6. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    You DEFINITELY have to do it. You owe it to yourself/your rig.
    <font color=red>"SETTING OFF ALARMS IN A CITY NEAR YOU!"</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
  7. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    A little bit of "I've been there before" advice. Many people use a screwdriver to drive out the old race and to set the new on in the hub. I screwed up a brand new hub many years ago with the old screwdriver method. I have since acquired a set of brass drifts from Harbor Freight (about $6.00) and I have had the same hubs since. They are just great to have around.
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
