New Blazer Owner...I have questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Biggedraws, Apr 15, 2001.
  1. Biggedraws
    Biggedraws Registered Member
    Apr 13, 2001
    57
    Gilbert, arizona
    I have a 1986 tuned port fuel injected 350 with a 4" lift on 33X12.5 15X10" rims, whats the biggest tires i can get with that lift and those size rims? My lock rite has gone out in my rear end i need suggestions on whether i should replace them with a new locker or just put the spider factory gears back in?
  2. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    If you don't do any hard core 4 wheeling, you can get 35's on without a problem. That's what I'm running and havent had a problem yet.
    85 Blazer on an 82 chassis, 6.2L Diesel, ORD flip, 35's with no cutting on a 4" lift.
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I have 36" Swampers with a 4" lift, 1" ORD body lift and some moderate to serious trimming...[​IMG] for a pic just check out the "Blazers can fly" post, the first pic is my truck.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  4. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    36's should fit but you could get a 2 inch body lift for like 150 bucks or less i am not sure. you could even probably sweeze bigger than 36 if you dont offroad.
  5. zach78k5
    May 14, 2000
    406
    36's should fit but you could get a 2 inch body lift for like 150 bucks or less i am not sure. you could even probably sweeze bigger than 36 if you dont offroad. if you gears are not 3.73 or lower good luck turning bigger tires though.
