New Bracket post, tons of pics, 52" front springs 1" lower in front
Discussion in 'The Garage' started by jjlaughner, Jul 13, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    New Bracket post, tons of pics, 52\" front springs 1\" lower in front
    Just like the title says I lowered the front mount 1" to help with pinion angle. I made all new brackets for the front ( first part of project here ). The brackets are bolted on and holding the front of the springs up. I need to drill the holes out to 9/16" in the front and buy some steel for shackles since the piece of 3/8" I have is to small to make all 4 shackles. I still need to do some bracing on the sides, once the bumper goes back on the front I'll have to brace the outside edges back to the outer bracket so it will be all tied back together. The 5" on the front of the brackets will be totally welded to the front 6x2" tube. To help hold the outside brackets in place I used the angle and welded around it and the angle bolts to the body mount cup. Then I'm going drill another 1/2" hole on the outside bracket in the center and use a 1/2" sleeve and use another 5" - 1/2" bolt (right above the front spring bolt up 4"). BUT, its almost ready for the front springs to go in and the front axle and tires!!!!! After that I'm planning a new engine crossmember since I'll have to go to crossover sometime. Once all the frame mods including bracing the steering box is done, I'll start tearing the front clip off the project blazer get the motor pulled cleaned up and transfer it and the tranny into the frame and start making some flat crossmembers. I need to sell some more stuff and buy the $55 clocking ring and the $49 14bolt disk brake brackets off ebay. Also I waiting on ORD to quote me a price on the new 1/2" upper frame bushings with the sleeves (no bolts), so I know how much cash I need to scrape together.
    ON TO THE PICS!
    I'll post up again once its all done sitting on the axle /forums/images/graemlins/waytogo.gif
  2. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Re: New Bracket post, tons of pics, 52\" front springs 1\" lower in front
    For some reason the brackets look crooked in a couple of the pics but they are square and within 1/8" top to bottom on width /forums/images/graemlins/dunno.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/screwy.gif
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Woah that looks really good /forums/images/graemlins/thumb.gif
  4. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Dude, thats a bolt on, you should market it. /forums/images/graemlins/thinking.gif
  5. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i was going to mention them being crooked and was wondering if that would screw up the ride. hope it works out and i wish i could weld like that!!!!
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    What years did the frames change in the front to where they used different bumpers? /forums/images/graemlins/thinking.gif
    This setup would fit what like an 81-up. Looking back at it I have figured out several ways to save alot of time, cutting and cleaning the edges. If I had a plasma cutter and a little heavier welder to where I could blast through 1/4" faster that would be an idea. I have about $40 in steel and hardware, plus about 6 (solid) hours in cutting and grinding and drilling. If I had a plasma machine like DIY the holes and round edges would be cake.
    Here's my rear diff cover from DIY, I got some steel (on the right) I need to cut and weld in.
    I'm going to use 3/8" on bottom because thats what I have, then I'll trim some of my left over 1/4" for the top and side sections.
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    still need to make the longer shackles and put my upper frame mounts back in. I just used the old shackles and bolts and hung the spring from the new hole (it was starting to rain I was going to use a bungie cord and hook it up at 7.25" to see). Looks like the springs will sit about level. /forums/images/graemlins/thinking.gif
  8. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    how soon ya planning on doing the motor? /forums/images/graemlins/wink.gif
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    as soon as this thing is on all fours
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Just as long as the secret weapon is there /forums/images/graemlins/ignore.gif
    /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/whistling.gif
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea you should deffinetly sell those. looks good /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
    the DIY4X dif cover you have is laser cut IIRC.
  12. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    I'm interested in seeing how your shackle angle turns out. /forums/images/graemlins/thinking.gif looks very good /forums/images/graemlins/waytogo.gif i like the design
  13. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Here's with no weight on the front
    Still need to triangulate this
    custom engine crossmember
